Discussion topic: Bad down load speed
Message posted on 18 Jun 2026 11:30 PM
Bad down load speed
For some reason our download speed is 1.5mb per second and for some reason when I test it the speed of the WiFi it says it is good when it isn't.
Message posted on 19 Jun 2026 08:07 AM
Re: Bad down load speed
@Noose21 wrote:For some reason our download speed is 1.5mb per second and for some reason when I test it the speed of the WiFi it says it is good when it isn't.
Is that the speed of the broadband to the hub or are you measuring speed over wifi, the two are not the same.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
