Discussion topic: No wifi
This message was authored by: Laura71
No wifi
WiFi keeps disconnecting however the tests are saying it is coming back as good however phone and laptop have no signals
Re: No wifi
@Laura71
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
