Discussion topic: No WiFi
Message posted on 22 May 2026 02:07 PM
No WiFi
Internet light is not on and your checker is saying it looks good. We have no WiFi?
Message posted on 22 May 2026 02:36 PM
Re: No WiFi
@Russo1
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
