Discussion topic: No wifi
Message posted on 14 May 2026 11:43 AM
No wifi
Broadband check says my WiFi is fine but this is untrue! Have lost all internet/WiFi to TV, phones and laptop. My internet is completely down despite resetting my hub twice. Worse thing is that when I'm checking your system tells me everything is fine!
Message posted on 14 May 2026 11:45 AM
Re: No wifi
@Millie88
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
