Discussion topic: No WiFi
This message was authored by: Vicky766
No WiFi
My WiFi has gone but all lights green and saying no issues
This message was authored by: Ram23
Re: No WiFi
I am having the same issue
Re: No WiFi
@Vicky766
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
