Discussion topic: No wifi
This message was authored by: Becky172
No wifi
There is no light on my router, the tv isn't finding myth wifi usernames
Re: No wifi
@Becky172
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
