Discussion topic: No wifi
This message was authored by: RBT1989
No wifi
WiFi went down and now there are no lights on the router and no WiFi however either cable is working fine. Tried going through all settings and no issues just WiFi signal has disappeared.
Re: No wifi
@RBT1989
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
