Discussion topic: No wifi
This message was authored by: Pattyann52
No wifi
Had broadband fitted thus morning now I can't connect to the internet
Re: No wifi
@Pattyann52
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
