Discussion topic: No wifi
This message was authored by: Mils1
No wifi
Currently have no internet, sky stream not working obviously, on the app it tells me there's an issue yet go to fix it and says there isn't one? There clearly is as I cannot access the internet.
Re: No wifi
@Mils1
▪️I AM NOT A SKY EMPLOYEE ▪️
