Discussion topic: No wifi
Message posted on 05 Jan 2026 08:30 PM
No wifi
Message posted on 05 Jan 2026 08:40 PM
Re: No wifi
@Samanthasmith66
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
