Discussion topic: No wifi
This message was authored by: K23wlk
No wifi
Yesterday day, everything was working perfectly fine. Last night my WiFi wasn't connected I tried the on and off trick not working. The reset button not working. Nothings working! And I pay for this **bleep**!
Re: No wifi
@K23wlk
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
