Discussion topic: No wifi
This message was authored by: Nicole-Darcy
No wifi
On the sky App it's tells me there is no problem with my sky or my broadband yet again we have no sky in any of the TV's in the home, we can't stream anything and none of our mobiles are working in WiFi . This has been going on now for almost two weeks. There is obviously a problem that needs dealing with urgently please helo
Re: No wifi
@Nicole-Darcy
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Avatar for Nicole-Darcy
Level 0 icon
Re: No wifi
The TV's will come on sporadically otherwise they have a blue screen with THERE IS A TECHNICAL FAULT displayed on all screens. As I've stipulated we cannot use our WiFi on our phones. Also we cannot use the streaming on any of the TV's
Re: No wifi
@Nicole-Darcy
Have you reported it to Sky in those two weeks? If so what have they said/done?
