Discussion topic: Internet drops out
This message was authored by: Carl116
Internet drops out
My internet drops out for 10mins 3/4 times a day . There is an issue on the network. Please send an engineer out
Re: Internet drops out
@Carl116
An engineer can't be arranged on here. You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
