Discussion topic: No wifi
Message posted on 20 Nov 2025 02:07 PM
No wifi
No connection with poor WiFi after sky checker
Message posted on 20 Nov 2025 02:28 PM
Re: No wifi
@JC098
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
