Discussion topic: No wifi
This message was authored by: NicolaBetts
No wifi
I am connected to my WiFi but have no Internet It's going in and out
Avatar for NicolaBetts
Level 0 icon
Re: No wifi
I have no Internet and keep being bounced out
Re: No wifi
@NicolaBetts
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
