Discussion topic: No wifi
This message was authored by: Sandra143
No wifi
Texted all connections test said everything ok but I have no network
Re: No wifi
@Sandra143
If it's a broadband issue use this link to check to see if there are any issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Re: No wifi
@Sandra143
If you have run a line test and rebooting your broadband hub at the mains doesn't fix it then you will need to call Sky about this.
