Discussion topic: No wifi
Message posted on 29 Oct 2025 10:54 AM
No wifi
I have tried everything to reboot the wifi but nothing has helped. It's almost an hour without internet connection now. Is anyone having the same issue?
Message posted on 29 Oct 2025 10:57 AM
Re: No wifi
@Peekay1
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
