Discussion topic: No wifi
This message was authored by: CW471
No wifi
No WiFi despite service checker saying no issues! Router showing 3 green lights
Re: No wifi
@CW471
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
