Discussion topic: No internet connection
Message posted on 18 Oct 2025 05:57 PM
I'm not able to go into my apps due to no internet connection
Message posted on 18 Oct 2025 06:00 PM
Re: No internet connection
@Jo348
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
