Discussion topic: No wifi
This message was authored by: Tanyalout
Message posted on 18 Oct 2025 02:12 PM
No wifi
There is no WiFi in our home the checker says there is a problem with your broadband but when I run the check it says there is no problem with the WiFi? What is going on?
Find out more
Message posted on 18 Oct 2025 02:15 PM
Re: No wifi
@Tanyalout You're only asking oither customers what's going on, it's likely an outage.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
