Discussion topic: No wifi
This message was authored by: Shane106
No wifi
WiFi keeps dropping out
Re: No wifi
@Shane106
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
