Discussion topic: No wifi
Message posted on 15 Oct 2025 06:18 AM
No wifi
Hello I have no wifi
Message posted on 15 Oct 2025 06:56 AM
Re: No wifi
@Stella34
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
