Discussion topic: No broadband
This message was authored by: Paulmorton
No broadband
I currently have no broadband despite my router showing 4 green lights after a restart, i have also connected via a cable yet still nothing.
Re: No broadband
@Paulmorton
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
▪️I AM NOT A SKY EMPLOYEE ▪️
