Discussion topic: No wifi
This message was authored by: Colin213
No wifi
No wifi its been off and on all day is there a problem TA2 area Taunton
Re: No wifi
@Colin213
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Avatar for Colin213
Re: No wifi
On the hub 2 of 3 light green Internet not working
Avatar for Colin213
Re: No wifi
It would seem there was an outage no providers knew about, social media had similar posts with wifi issues
