Discussion topic: No wifi
This message was authored by: rockyrocasel7
No wifi
ON light red
Avatar for rockyrocasel7
Re: No wifi
PON. LIGHT RED
Re: No wifi
@rockyrocasel7 the red PON light means the ONT is not receiving an optical signal. At the time you posted the most likely explanation is Openreach are working on the OLT unit at the exchange that generates the signal if so it will come back up by morning. If it hasn't call Sky to report the fault.
