Discussion topic: No wifi
This message was authored by: S_HOWITZ
No wifi
Internet cut out approx 30 mins ago. Steady pulsing green light on router. No issues detected on "my sky" but still no Internet. Phone shows connected but no Internet. Router plugs into openreach box which shows as red light on LOS, green on power and green on LAN
Re: No wifi
@S_HOWITZ
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
