Discussion topic: Internet not working
Message posted on 23 Aug 2025 07:18 AM
Sky tv says no internet connection I've run all the tests and done reset still not working
Message posted on 23 Aug 2025 08:03 AM
Re: Internet not working
@Lararoach
So if your broadband isn't working at all use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
