Discussion topic: No wifi
This message was authored by: MkTaz-62
No wifi
Hi is anyone else in the M26 area having an issue with sky Internet/WiFi  as mine seems to have gone off.. TIA
25/6/25
Re: No wifi
@MkTaz-62
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Avatar for MkTaz-62
Re: No wifi
Thank you... it has resolved itself somehow . 🤷‍♀️ thank you for taking time to reply much appreciated x
