Discussion topic: No wifi
This message was authored by: Kathrynhgh
No wifi
Hi my wifi will not come back on
Re: No wifi
@Kathrynhgh
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
