Discussion topic: No wifi
Message posted on 12 May 2025 03:50 PM
No wifi
Yesterday my WiFi went down. I have re set the box but there is no Internet light on green and no WiFi to devices
Message posted on 12 May 2025 03:57 PM
Re: No wifi
@Charlotte160
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
