5
This discussion topic has been answered Discussion topic: Mains cable for sky router
This message was authored by: Podzol
Hi.  How can I get a replacement mains cable for a Sky router that had been chewed by a puppy?
Re: Mains cable for sky router
@Podzol
Your local DIY or electrical shop or online sites like Amazon etc....
@Podzol
Avatar for Podzol
Ok, thanks.  I wasn't sure if I should ask Sky if they can provide a replacement.
@Podzol You may wish to say what sky hub you have, as there are different leads, and if the puppy chewed through a mains lead hope it is still living?
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for Podzol
I should describe it as a power cable rather than mains lead!  It is for a Sky router and the wire carries a very low current (amperage) as it is transformed by the plug before entering the cable.  And yes, thankfully the puppy is still alive!
@Podzol The link i sent you shows the Sky hubs, so get the correct name that you see, and call sky to get a replacement, they may charge you for it or even a delivery charge. Below the link will get you to the phone number that is embeded unless you all ready know it.
https://www.sky.com/help/home
