Discussion topic: No wifi
This message was authored by: MrsJP
No wifi
No WiFi since last night
Re: No wifi
@MrsJP
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Re: No wifi
@MrsJPYou mean you have no broadband, what happens when you run the service checker and the broadband test on your connection via the Sky app?
Re: No wifi
@MrsJP
Your duplicate thread has been removed and the reply to the other one moved here.
Avatar for MrsJP
No WiFi
WiFi came on after none since last night but now gone off again. Sick off this!
Re: No WiFi
@MrsJP
No need for another new thread. Stick to this thread for this issue.
Have you carried out the troubleshooting already mentioned?
By the way, in case you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
Re: No WiFi
@MrsJP
You don't appear to be taking notice of our replies. Your latest thread stating the same has been removed.
