Discussion topic: No Internet light on broadband hub
Message posted on 27 Apr 2025 05:00 PM
Internet dropped around 4.30pm and the light hasn't come back on.
The sky broadband checks show that everything is fine.
Message posted on 27 Apr 2025 05:16 PM
Re: No Internet light on broadband hub
@Dec201
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
