Discussion topic: No wifi
Message posted on 08 Apr 2025 05:49 PM
No wifi
Message posted on 08 Apr 2025 05:55 PM
Re: No wifi
@NathanSid
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
Message posted on 08 Apr 2025 06:17 PM
Re: No wifi
Hello, I have tried all this unfortunately it says the connection is good but still no broadband, unable to connect.
Message posted on 08 Apr 2025 06:19 PM
Re: No wifi
@NathanSid
To call Sky dial 150 (free) from your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
