Discussion topic: No wifi
Message posted on 06 Mar 2025 06:35 PM
No wifi
Tried lots of time now with the checks on app, just keeps saying I'm connected.
it's not connected!
Message posted on 06 Mar 2025 06:59 PM
Re: No wifi
@Darryl6
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
