Discussion topic: No wifi
Message posted on 27 Feb 2025 08:37 PM
No wifi
No WiFi at all m. The light in the box is orange. We have tried to re set and still not working
Message posted on 27 Feb 2025 08:54 PM
Re: No wifi
@SophieH2
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
