Discussion topic: No wifi
Message posted on 31 Jan 2025 03:57 PM
No wifi
No proper wifi
Message posted on 31 Jan 2025 04:03 PM
Re: No wifi
@Swella
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
