Discussion topic: No wifi
This message was authored by: MJB6
No wifi
You tests say it's fine and you have tested the hub - all good. The lights flashing orange!!!!
Re: No wifi
@MJB6
We are customers here but if you haven’t done it already use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
▪️I AM NOT A SKY EMPLOYEE ▪️
