Discussion topic: No wifi
This message was authored by: Toni11
No wifi
Hi,
My WiFi has been of for 30 minutes now, no Internet and will not connect
Re: No wifi
@Toni11
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
