Discussion topic: No wifi
This message was authored by: Sydrah
No wifi
There is no wifi available since 4pm today & the white light is not on on my sky max hub I have tried resetting it by switching it on & off again but no change. There has been no Internet connection all day. What do I do to resolve this issue ?
Re: No wifi
@Sydrah
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
