Discussion topic: No wifi
This message was authored by: Kayleigh63
No wifi
Hello,
my WiFi connection is down.
thank you
Re: No wifi
@Kayleigh63
We are mainly customers on here trying to help other customers and you aren’t directly contacting Sky Customer Services.
The first thing to do is check to see if there are any outages in your local area via this link https://www.sky.com/servicechecker
If there isn't try running the line test here
You can also run the test via the MySky app on a mobile data connection. Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on screen instructions.
