Discussion topic: No wifi
This message was authored by: Magsmarcus
No wifi
No devices can connect to wifi. Wifi name not showing up on list of available. Hub showing white light
Re: No wifi
@Magsmarcus
There's a known current issue with the white Max Hub:  a workaround is to factory reset the hub by holding down the WPS button for 30 seconds. Once this is complete, any previous changes you've made should be downloaded again from 'the cloud'.
