Discussion topic: No wifi
Message posted on 25 Jun 2024 03:33 PM
No wifi
We had the broadband box sent out on 17th June but wifi is still not working. On the app it says all connections are good, but when I phoned Sky it said 'issue with new home set up', but did not elaborate further.
help please!
Message posted on 25 Jun 2024 03:34 PM
Re: No wifi
Update:
wifi is green light but internet light is flashing amber
Message posted on 25 Jun 2024 03:41 PM
Re: No wifi
Some more context would be useful. Why were you sent a new router? Is it an exisiting connection with an upgrade or fault resolution or is this a new connection?
Message posted on 25 Jun 2024 04:32 PM
Re: No wifi
Hi James
We have just moved into the property so it is a new broadband connection. The wifi light on the box is green, but the internet light is flashing amber.
thanks
Message posted on 25 Jun 2024 04:35 PM
Re: No wifi
Hi James
any help appreciated!
thanks
Message posted on 25 Jun 2024 04:37 PM
Re: No wifi
So you received the router on the 17th June but what was your connection activation date? Does the Sky order tracking confirm the activation was completed?
If it does then ensure you are using the master telephone socket (or Openreach ONT) and you are using the supplied cables from Sky.
Message posted on 25 Jun 2024 04:43 PM
Re: No wifi
I got a text from Sky on 17th in the afternoon, to say Broadband is now active.
I have reconnected the cables etc again and it is still flashing. For some reason on the app it says there are 6 devices connected to it but we haven't moved in yet..
when I phoned Sky earlier it just said 'issue with new home set up'
Message posted on 25 Jun 2024 04:52 PM
Re: No wifi
I have escalated your post to sky, look out for a message on the forum
Message posted on 26 Jun 2024 08:40 AM
Re: No wifi
Thanks for escalating. We've sent an invite to @Harriet271.
Tom
