Discussion topic: No wifi still
This message was authored by: hootie63
No wifi still
Nearly 24hrs and still no WiFi after going down at 12.30am 27th.
Had to use my data for work purposes from home, emailed sky and had no reply.
Very poor set up and customer service ... Communication Zero.
No streaming service, no home phone, no WiFi. No communication.
Re: No wifi still
@hootie63
Sky don't use email for general communication or fault reporting.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
