Discussion topic: My internet keep malfunctioning everyday
This message was authored by: Chibuzo
Fault in my wifi
Re: My internet keep malfunctioning everyday
@Chibuzo
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
