Discussion topic: No wifi connection
Message posted on 24 Feb 2025 06:24 PM
No wifi connection
Message posted on 24 Feb 2025 06:26 PM
Re: No wifi connection
@Hezza121
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
