Discussion topic: No wifi but broadband working except for side button showing orange
This message was authored by: MHarrison
Wifi on tv glass not working 2 and a half hours. Only tv programmes are on terrestrial tv.
Re: No wifi but broadband working except for side button showing orange
@MHarrison modt likely issue is overnight maintenance work which should complete by 7am at the latest. Openreach who own the network have to maintain systems so occasionally you will lose connection after midnight until thecesrly morning.
However if your Sky hub shows it has lost connection by the time Sky's lines are fully open to 8am and thecservicecchecker in the My Sky app is not offering help call Sky.
Avatar for MHarrison
No wifi for Glass tv on Sky+
Nothing on Sky+ for 7 hours....no wifi so cannot connect with Sky tv+ just no wifi connection
Re: No wifi for Glass tv on Sky+
@MHarrison  Your latest post has been merged to your existing thread, you other thread you crested has been removed, you don't need to raise multiple threads, it won't help get any issues resolved any fatser by doing so.
You neeed to fillow the steps given by by @Chrisee above if your broadband is still down.
In your other thread that has been merged to this one you mentioned Glass TV as well as Sky+?
