Discussion topic: No wifi AGAIN!!
This message was authored by: till1989
No wifi AGAIN!!
Happens most days test says there is good commenting but obviously not. Tv and all other Internet devices are unable to connect. So frustrating when its a service we have to pay for!
Avatar for till1989
Re: No wifi AGAIN!!
Obviously I meant good connection! Happy new year 🥂
Re: No wifi AGAIN!!
@till1989
The first thing to do is check to see if there are any outages nearby via this link
Once completed, if it reports back that all is good click on 'broadband' to run an updated test. If you get amber or red you need to follow the on-screen instructions.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: Kazza270
Re: No wifi AGAIN!!
Ours is the same!! Absolute **bleep**!!
Re: No wifi AGAIN!!
Always says no outages in your area
Re: No wifi AGAIN!!
@Kazza270
'no outages in your area' doesn't mean your own individual circuit isn't out of action.  It's intended to indicate that there's no known upstream fault affecting multiple households, but is worded very poorly.
This message was authored by: seast1
Re: No wifi AGAIN!!
I have same issue. No internet since 21st december  then worked yesterday and no internet again with soonest engineer visit 11th January.
