Discussion topic: No way fi
This message was authored by: Denisewhite
No way fi
I have had no wi fi since last night
Re: No way fi
@Denisewhite
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
