Discussion topic: No voice light on router
This message was authored by: cwiles
After a couple of powercuts due to bad weather, our router no has no voice light at all. All of the other lights are green but the voice light is completely off for the last 24 hours, leaving us with no internet.
Re: No voice light on router
@cwiles
The voice light is for your landline talk service so have you tried rebooting your broadband hub at the mains.
If you have and it is still the same the the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for cwiles
I have tried these tests multiple times throughout the day, restarting the router and leaving the router off for a while all did not work and the voice light still remains off and all devices are able to "connect without internet"
It's having a fault in the external internet connection which causes the voice light to be off.
Avatar for cwiles
Still no internet or voice light after 2 days...
